Results 1 to 9 of 9
  1. Hi,
    I wrote a movie to an ISO file - it came to a total of 3.7GB - when I tried to burn it to an erased DVD+RW Disk with DiskAtOnce it said 'This will not fit on any disk' - When I tried the same thing with Roxio DVD Builder it said (essentiall) 'Not Enough Space'
    Any ideas?
    I know nothing - and I have witnesses to prove it!
  2. Did you try DVD Decrypter? And even thou the iso is 3.7GB what size do the programs think it is?
  3. i have the same problem at the moment. I have a movie that a put on a blank 4.7gb DVD+RW, but when i go to write it to a 4.7gb DVD+R is says not enough disk space.????Confused
    sasArchiver
    AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
    160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
    ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
    DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights
  4. Yep DVD Decrypter always delivers.
    And it can overwrite DVDRWs even if its not empty
    If its problematic do a full format before writing!
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  5. >Vejita-sama Did you try DVD Decrypter?
    I haven't tried DVD Decrypter - I thought that was only for decrypting commercial DVDs - whereas I'm trying to burn one I've authored myself. Have I missed something?
    Roxio DVD Builder doesn't say - but now what you mention it, BurnAtOnce did indicate (in the header I think) that the disk had '0 bytes available' - this bit had me confused as I'd just finished 'erasing' (not formatting) the disk.
    Does a DVD+RW need to be formatted after being erased before it can have a DVD Movie burned to it?
  6. DVDInfo PRO is the best at quick/full formatting.
    DVD Decrypter does not require empty disc before writing ISO the other programs do.
  7. I'm totally familiar with erasing / fast formatting / full formatting a 'conventional' storage device (like a hard disk drive) - are you saying that a DVD+RW may need to be formatted in exactly the same way (especially if I've 'erased' it using a program that may not fully erase according to published standards?) before an IS file can be burned to it?
  8. I'm saying Roxio is not the best choice when it comes to dvd burning.
    DVDInfoPRO follows the MMC specs while others don't.
    A full format might help.
  9. Yes, DVDInfo Is great for formatting.
    I usually use the Quick Format with "compatible" selected.
