Hi there,
Trying to make a regular sound CD out of a karaoke VCD-stream.
What tool could help me extract wavs from the vide0/audio stream of a VCD?
Thanx
Dryson
1) Demux MPG to MPV (m1v/m2v) and MPA (MP2) w/ TMPGenc
2) Convert MP2 to wav file (most of your MP3 <-> wav software should be able to do this). -
Another simple way of doing this is to simply load the MPEG with VirtualDub and then save the audio as a WAV file.
Regards.
Michael Tam
w: Morsels of Evidence
How to extract audio from a VCD?
By c1steady in forum AudioReplies: 2Last Post: 14th Jan 2010, 21:16 -
How do I extract eac3 dd+ audio to mono wavs?
By yoda313 in forum AudioReplies: 15Last Post: 14th Feb 2009, 19:22 -
Easy way to extract audio (DTS) from a .m2ts stream and convert it to AC3?
By marklight in forum AudioReplies: 1Last Post: 8th Sep 2008, 18:42 -
Extract audio only from VCD
By ambrosechapel in forum AudioReplies: 2Last Post: 19th Aug 2008, 22:24 -
Extract problem dolby audio from transport stream
By DVWannaB in forum Video ConversionReplies: 7Last Post: 17th Aug 2007, 23:35
