Missing Media Burner gives this info for CDR/RW disks but not DVD's. Any other software that does this for DVD's? Toast 6 "disk info" only tells you space on disk and the speeds the disk can be burned at. I'm trying to find out who made these generic disks I just bought at PC Club! Thanks
i dont think that there is anything that will tell you this under OS X.
yea unfortunately we are out of luck
even running VPC and running the dvd info.exe doesnt work becasue it gives some blah blah blah error about how the dvd function of the drive is not supported !
until that is supported there wont be a way, unless some genious OSX writer will make a similar app for OSX.
You think someone would!?!?
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 14:43 -
Best dvd software for mac. os x
By fpunky in forum Newbie / General discussionsReplies: 9Last Post: 29th Jun 2012, 22:09 -
MAC DVD Authoring Software
By Crossdive in forum MacReplies: 10Last Post: 23rd Feb 2010, 14:13 -
question about where bad hard drive disk sector info is stored
By jimdagys in forum ComputerReplies: 1Last Post: 20th Apr 2008, 17:24 -
Software to view technical info of dvd video
By cengoh in forum Software PlayingReplies: 3Last Post: 28th Sep 2007, 04:59
Quote![Computer details: OSX 10.2
800 mHz G4
60GB
512MB
Geforce 2 MX [crap]
Panasonic Q [SL-GC10], AVX-100 Divx Player
Apple Superdrive
PowerPC G4
Edirol UA-20, iPod, Midiman Ozone, AVX X-100 Comp](/images/buttons/computer.gif)
