Hi
I finally backed up my first DVD using the VIDEO_TS folder and the AUDIO_TS folder and. The DVD plays fine on my DVD drive on my computer, but doesn't play on my DVD player. The DVD player says that it isn't the correct format. Is it my DVD player? Its around 3 years old. What am I doing wrong. It took me about a week to figure out how do backup a DVD, and now this.
Look up your player here (you have not named it) https://www.videohelp.com/dvdplayers
see if it's listed & whether it likes + or -There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
My player is a Panasonic A110. It plays DVD's backed up with DVDXCOPY fine, but doesn't play when I try to fit a DVD9 onto 1 DVD. I follow the instruction to the letter, but I still don't know what I'm doing wrong. I use DVD shrink and nero, as well as copytoDVD. I think I'm doing something wrong when trying to burn but can't figure it out.
Don't know what you may be doing wrong, but you'll get more help if you go back and edit the title of your post to reflect your question more accurately. :c)
Lots of people skip over those that just say "Help".There's no place like 127.0.0.1
I have an A120 and I haven't had any problems with +R media (namely Memorex 4x +R - manufactured by Ricoh) playing on it, I have had some problems with -R though, mainly Verbatims, some Riteks and, of course, Princo.
However, seeing that you have an even older A110, it is quite possible that it may not even like +R media.
FWIW, I too have an LG GSA 4040 burner. -
Your standalone might not like +R discs. I have the same burner. I recently burned a movie sample for a female I know, and the sample was on a Ritek G04 -R disc. It didn't play in her standalone. I then burned the same movie sample on an HP 4x +R disc and it played fine in her standalone. Her standalone is the very first I've run across that won't play -R discs, and I'm assuming it won't play ANY -R's, because the sample I used was a Ritek. It's not going to get much better than that as far as disc quality.Originally Posted by pelsamra
I think what we really need is to know WHICH instructions your using to burn... as well as what program.
I assume you remember to put the AUDIO_TS and VIDEO_TS folders in CAPS right?
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 11:24 -
AVStoDVD 2.3.2 - Process aborted during DVD Burning Operations
By Mark97213 in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2010, 14:05 -
AutoGK keeps screwing up my resolution.
By mob in forum DVD RippingReplies: 5Last Post: 30th Aug 2010, 07:34 -
DvdShrink process stuck after burning to dvd .
By fibola in forum Authoring (DVD)Replies: 8Last Post: 19th Sep 2008, 11:17 -
Any suggestions for getting educated on burning process?
By Cathyq in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 08:44
