I have a Pioneer AO4 and generic media DVD-R from americal.com I’m finding that all my old disk won’t play any more in my DVD players were they worked fine before. Is anyone having this same problem or what media would you suggestions for this drive?
Jim
That is a potential problem with certain media, low quality media can go bad over time (the dies, etc). Do you have any other media of similar burned age. How old are these media? Can they play anywhere other than your DVD player??? You can probably find good quality, low cost media, but you have to be careful to avoid this problem again.
Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge. -
Yes. I had the same problems. The Americal.com media was LeadData, Princo silvers, and Ritek G1. All of them were 1x discs, silver or gold tops, and they have since "died". However, it may be any number of things, including it being bad all along, player now dirty, etc. The "dvd rot" idea is still being pursued, having not been proven to date. Too many variables.Originally Posted by jim sWant my help? Ask here! (not via PM!)
My data discs are find its just seems to be my dvd video. What media would you suggest to buy?
Jim -
There is no difference between data and video dvd's, both are "data" disks. Have you tried to play them in your pc?Originally Posted by jim s
Buy Ritek, they make the best media"Terminated!" :firing: -
Do you have a Retail DVD to test with, does it work in the player? If your Data DVDs of the same media work fine in your PC, but nothing (Burned DVDs, Retail Movies) will play in your DVD player, it may be the DVD player (I have had a player die on me out of nowhere). Can you find another DVD Player at a friends house and try your DVD-R media there.
What you need to do is determine which media will work in which players/drives, and see if a pattern forms.Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge.
Good quality? What changes could be made?
By darkdream4 in forum DVD RippingReplies: 78Last Post: 11th Jan 2010, 22:35 -
Have I made the quality too Good?
By criddle in forum Video ConversionReplies: 1Last Post: 4th Apr 2009, 04:37 -
DVDs made with ffmepgx
By dlg1989 in forum ffmpegX general discussionReplies: 1Last Post: 11th Feb 2009, 15:05 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 21:59 -
Unplayable dvds made on Sanyo DRW-500
By ronl44 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 6th Dec 2007, 13:25
