hi
i wanted to know what this cube with a lot small cubes inside it is,it jumps
around all over the screen while playing the movie file.
sometimes it's not in the orignal file but when i encode it to an other file format it shows.
what is this thing and is there a way to get ride of it
goingape
Results 1 to 15 of 15
sounds like........ it is trialware encoding and that's like their watermark, but can't say for sure if you don't say what programs you used. :c)
It's probably not there if you purchase the program.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
It's the matrix being born. :P
awwwwww Baby Matrix :c) sweet
Originally Posted by goingape
Your using a trialware mpeg2 codec from Moonlight-Elecard.
You will have to uninstall it to get rid of it. Should be under start - config panel - add/remove programs. I suggest after uninstalling it you download the trail version of WinDVD or PowerDVD install that and use the mpeg2 codec from that.
I know this, because I was looking for a mpeg2 codec for watching videos and ran across that codec and saw the squares after I installed it. Then read in these fourms that if you install WinDVD or PowerDVD they have thier own codecs and even if you uninstall them (win, power dvd) after the trail period ends their codecs will remain.
Moonlight-Elecard MPEG2 Video Decoder kit
http://www.elecard.com/products/mpeg2decoder.shtmlIF YOU CAN READ THIS THEN YOU THEN YOUR EYES ARE DAMN GOOD! PLEASE, LET ME KNOW, BECAUSE I AM IMPRESTTED WITH YOUR GREAT VISION. LOL. BY THE WAY PEOPLE SUCK. EVERYONE SUCKS. -
:c))) Why didn't I think of that!!??
Bluewolf2005 hit the nail on the head. Uninstall the elecard mpeg2 codec.
i have check and i don't seem to have an elecard mpeg 2 codec installed
is there a program with wich i can check what kind of mpeg 2 codec's are
installed
but you are right about windvd i got a reg version and when you play the movie file in it ,the cube seem to be gone.
goinape -
GSPOT, and then open and render an MPEG file.Originally Posted by goingapeWant my help? Ask here! (not via PM!)
i use g-spot and it seems that there must be an elecard mpeg 2 codec
installed on my computer
the problem is that it is not listed in the add/remove so i can not uninstall it
is there any other way to uninstall it or is there a program that can do that
for you.
because i have no idea where the elecard mpeg 2 codec is installed.
goingape -
GSPOT will tell you the EXACT codec location of you click on it. Manually go and delete the file. Reboot. Should be good now.
'AnalogX DXMan' shows most codecs - also has a remove button!
http://www.analogx.com/contents/download/audio/dxman.htm -
thank
with dxman i had the elecard mpeg 2 codec easy removed
quite a nice program.
after i had the elecard codec removed it seems that the jumping cube problem also was solved
thank you all for the help
goingape -
maybe that's good candidate for the TOOLS section :c)'AnalogX DXMan' shows most codecs - also has a remove button!
unless it's there already, I didn't spot it.There's no place like 127.0.0.1
I have a really strange problem with movie files
By Jimbo1 in forum Newbie / General discussionsReplies: 6Last Post: 14th Mar 2011, 07:53 -
REALLY STRANGE RARE THING: MPG video CHANGED after file transfer or copy
By xboxsold in forum Newbie / General discussionsReplies: 21Last Post: 1st Feb 2011, 10:28 -
Jumping over movie
By gbabione in forum DVD RippingReplies: 3Last Post: 11th Apr 2010, 05:54 -
i need help with a strange thing about frames in mpeg files...
By DjSonicx in forum Newbie / General discussionsReplies: 2Last Post: 24th Aug 2009, 15:22 -
MediaPlayerClassic ... doing a STRANGE thing... any ideas ?
By halsboss in forum Software PlayingReplies: 8Last Post: 15th Mar 2009, 05:45
