  1. Member videocheez's Avatar
    Jan 2003
    I have a three half hour dvd's of some scateboarding flics and I wanted to put them all onto one dvd and have three menu's to point to the movie that I want to watch. I use DVDA for authoring. I used DVD decrypter to get the VOB's onto my hardrive but I need to know the method to add each movie to a blank DVD. Any suggestions or guidaance will be appreciated.
    Thanks in advance
    VC
    This is so much fun!
    May 2003
    Pal Realm
    you can convert those vobs back to mgs (if you do not have software that accepts vobs) and then re-author.
    Do a search on "vob to mpg" here on this site.
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
    Mar 2003
    California - USA
    Try DVDlab (mediachance.com) it accepts vobs and is very easy to use.
    will take you no time to create a simple menu and author.
    AKA Zaphod
