Arghhhhhh ........... same thing happens , I convert avi to mpeg-2 with TMPGEnc ok , when I go to author it in TMPGEnc it will not recognise it as it has become a MCF file ????.......
Please help before my PC or brain explodes ( I think brain will go first)
Results 1 to 14 of 14
lord-
you keep starting new threads for (basically) the same exact problem. Soon a Mod will come along and lock your threads and you'll get no help. :c(
Please, maybe the time has come to not be so stubborn :cD and try the other suggestions that were offered to you.
:c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
No problem :c) I don't want you getting into any trouble in these early days, without even knowing.
I can't tell what's going wrong with the Tempgenc. If I were you I'd try something else - that's less headaches for you! :cD
You can always go back to Tempgenc at any time.
But I betcha it'd feel real good to get one working file out of your weekend, right? :c)There's no place like 127.0.0.1
It appears you are selecting the wrong Codec in the program for output. I believe "MCF file" is MPEG4, not MPEG2
Good luck. -
Oh bottleneck - good - you recognise that. Maybe you'll be able to Help LL. He's trying really hard. :c)
I had never had a file come out like that, so I was useless. :c)There's no place like 127.0.0.1
He may mean Tempgenc DVD author. He may be using both.
OK to clarify - you are using Tempgenc to encode then trying to use that in Tempgenc DVD Author. The 2 separate programs.
Did you see bottlenecks reply? Try the Tempgenc (encoder) Guide again and check each step.There's no place like 127.0.0.1
Are you using the standard DVD template in TMPG? Have you made any adjustments to the audio frequency, resolution, etc? If I'm not mistaken MCF stands for multimedia container format which is a distinct format different from avi and mpg.
I have been converting DivX encoded AVI to MPEG-2 for awhile now and I follow the wizard at the start up of TMPGEnc for NTSC DVD's. Follow the wizard (no OZ jokes here please) and you should come out with an MPEG-2. I also use TMPGEnc DVD Author for my DVD's projects.
"Can You Dig It!"
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 23:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 10:08
