I have 2 avi files but i want one so i can convert it to mpeg and set in in one file on dvd.... How can i merg 2 avi files?
Virtual Dub can do that. Load your first avi into it then choose
File>append avi segment. Load your second file, then choose
audio>direct stream copy
video>direct stream copy
file>save as avi
Your two avi segments will now be saved as one avi. One caveat; if you get a message from virtual dub that the audio in either file is a VBR audio
(variable bit rate) you will have to save the audio files as wav files. If you don't, your final avi will probably be out of sync. -
You could try "Easy Video Joiner" but be shure to check the result (possible audio sync problem) before deleting the originals!
http://www.doeasier.org/joiner/
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 23:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 21:32 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 09:16 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 05:24
