got a weird prob.
i have a mpg file that i want to encode in vcd (no prob with that)
the prob. is that i load the file in tmpgenc and encode it , tmpgenc finish ;all ok. tha fact is that the end of the file is missing ???(about 40s)
when i play the file with ati file player the vids time is 4:18 min.
but when i play it with powerdvd the vid time is 4:50 min.
WEIRD!!!!!!!!!![]()
i have try to open the file in vdub --) error mpg unexpected at the end.
have try to open with vdub mod --) the vid time 0:42 min
ouf!!!! bizarre !!! im confused![]()
what should i do to grab theses 40s missing vid at the end
need your help please
It's a corrupted MPEG. PowerDVD just skips over the damage, as scratched damaged DVD's are common. TMPG barfs like it does on any corrupted file.
There are MPEG 'fix' tools that may let you re-encode it. You can also try de-muxing/re-muxing it. You may have to cut it at the bad part, then skip ahead some number of frames and cut it again (cut out the bad part).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
thanks a lot gazorgan,
will try to find theses mpeg fix tools
when i got some corrupt file , i open it with vdub to see the bad frames but with this file i cannot open it.that's why i ask for some solution :P
thanks a lot for your time ,
ok have try this:
demultiplex file : result--) only 42 s of the file is demultiplex ?????
mpeg corrector result --) no change , the 40 s still missing in tmpgenc or mpeg player.
please any help , or suggest me a good mpeg repair soft.
p.s mpeg repair software had no free or trial version .
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 18:31 -
Having weird problem with MeGui encoding
By ayim in forum Newbie / General discussionsReplies: 7Last Post: 8th Sep 2010, 04:25 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
x264 encoding, transparent line? weird contrast?
By squall0833 in forum Video ConversionReplies: 12Last Post: 16th Jun 2010, 21:49 -
Weird YouTube encoding with HQ/HD
By greg400 in forum Video Streaming DownloadingReplies: 9Last Post: 5th Feb 2010, 11:26
