back again , I am going to persevere with this TMPGEnc encoding .
I have now got as far as pressing the start button and I get a message
You are trying to create mpeg-2 file , to playback mpeg-2 file DVD software is needed ? , then I press ok and message pops up cannot load
P3Package.dll
Any help appreciated please...
You should download an MPEG-2 codec, or buy Cyberlink PowerDVD which is a good player, and includes a codec.
I'm not sure about the second part of your problem, but maybe that will also be fixed if you do this. -
lord-lucan
The first message TMPG gives you can be ignored as far as encoding goes. It's TMPG's way of telling you that you cannot view the video you are creating on your computer unless you have the proper software (i.e. WinDVD or Power DVD). As far as the second message goes try reinstalling TMPG. When you open up the folder where TMPG resides you should see an icon labeled P3Package.dll. That should solve the problem. -
thanks Laddydaddy , done this and now encoding.......
hope no problems this time authoring...... I will be back as they say
Mpeg vs. Avi for VHS to DVD
By smartel in forum Newbie / General discussionsReplies: 4Last Post: 1st Jan 2011, 11:39 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
dvd to avi or mpeg
By AeR0 in forum Video ConversionReplies: 3Last Post: 22nd Jan 2010, 13:45 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
DVD to MPEG-2/AVI
By Nitro89 in forum DVD RippingReplies: 21Last Post: 14th Apr 2008, 15:17
