I recently talked to a Panasonic dealer locally about this problem and was unhappy with their response. I want to copy some movies on noncommercial DVDs I made using the HS2 to a VHS tape. The dealer says I cannot do this. I also noticed there were no instructions in the HS-2 manual explaining how to copy from DVD-r to VHS.
Has anybody had luck copying noncommercial DVDs to VHS? If so, how do you do it?
ALSO--anybody use the DVD Red Pro?
thanks!
All I did was conect the output of my Norcent DVD player to the input of my Sanyo VCR. Hit record on vcr and play on DVD and away we go
I only did a couple copies this way of the same disk for people without DVD players, but no problem at all! There should be no reason you cannot do it. If your DVD player prevents you from copying your own disks any way you want, it ain't worth having!
I think I did read somewhere some players might encrypt the signal for a non encrypted disk anyway. Don't buy those players if you find one!
I made the original DVD R from camcorder, not from comercail DVDs or Tapes!
Problems in copying DVDs that were "dubbed" from VHS
By Quonzer in forum Newbie / General discussionsReplies: 10Last Post: 4th Apr 2011, 06:30 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 21:03 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
Copying some home video on VHS to DVD
By syilim in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2008, 21:23 -
dvd recorder/vhs copying question
By nobbydadog in forum DVD & Blu-ray RecordersReplies: 6Last Post: 28th Dec 2007, 06:58
