i have a load of avi files which i am converting to m peg so i can play them as a vcd on my dvd player i have re encoded a few of the files to m peg using tmpegenc but when they play back in m peg format on my pc there is no sound at all??? what am i doing wrong??? and also the programs are only 25 mins long but when i re encode them to m peg they come out at 75 mins long??? and when i play them back the m peg clip is there at the start only 25 mins then there is just 50 mins of black screen at the end??? is there a program that i can use to cut out the dark 50 minute long section at the end of the clip???? many thanx!!
regards
paul
https://www.videohelp.com/forum/userguides/91597.php
maybe that'll help?There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Virtualdub will work as the guide saya, I've done it many times. Tmpge will let you trim the files, use the wizard and it's the first selection on the filters page (can't remember the name offhand)
am i doing something wrong when i use tmpegenc for the converted avi files to m peg file for there to be no sound????
ffmpegX: no sound when converting a imovie *.mov-file
By acid_burn in forum ffmpegX general discussionReplies: 2Last Post: 27th Dec 2011, 00:40 -
AVI converting sound issue
By wickerstick in forum Video ConversionReplies: 1Last Post: 23rd Jul 2009, 06:53 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 16:12 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56 -
No sound when converting FLZ file to AVI DivX!
By zanyjudy in forum ffmpegX general discussionReplies: 3Last Post: 14th Sep 2007, 06:02
