Hi, im really new on this. Bought myself pinnacle studio dc10 plus,with studio 8 editing.Ive done a dvd with it,mp3 music on too.Now, in laymens terms,what leads do i connect and where to to get the audio sound from my analog camcorder onto my capture.Also,where do my leads attach to for copying videos to dvd?and also,where do leads go when i want to capture from pc onto vhs. i used s/video lead to capture from analog camcorder onto pc to do my dvd,havent used scart lead or composite leads.Just really need to know where they go when doin these operations.Do i use leads into back of my sound card? can someone email me at dave30al@ntlworld.com i really want to get into this editing,best to do it right tho,cheers.
well...thats a great help...thought this was a place where people help each other...
Whoa.... that was a legitimate question asked.
Someone may have your exact camera and be able to tell you precisely how it's done.
That was your first post, and you'll soon find a good attitude, along with providing ALL info from the start will go a long way in helping you solve problems.
You should apologise right away if expect to hang around here for any length of time.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
okie dokes...sorries...ive got a Sony handycam,tr918e,thats why i bought studio dc10 plus,was told does really good analog capture,trying to setup a editing desk,got pc,vhs recorder,tv etc,just confused on where i connect my cables when i want to do certain functions,have scart connections on tv and vhs,2 x s/video connections and 2 composite on capture card,im confused with the 3leads (red,white and yellow)which to plug in for which function,and have scart adaptor with input/output switch.i got no info when i bought studio,been trial and error up to now,looking for inspiration,or someone wiv loadsa patience.
That's better. :c)
I am sure someone will be able to help now.
Just remember if you expect patience, you've got to give a little and have a little too.
I don't have the DC10 so I can't help with that. Does it have its own audio in? If not, you'd go in through your sound card, but I bet others who use one and will tell you.
Good luck. Hope you get lots of replies now. :c)There's no place like 127.0.0.1
I don't live in a PAL country so don't understand SCART
but
YELLOW is Video..
goes from composite CAMERA VIDEO OUT to Pinnacle DC
studio VIDEO IN
Red and White are audio left and right..
You might be able to use S-VHS out instead of the YELLOW wire , tho..
You need to find the S-VIDEO in on the Studio 10 card, ad leave the yellow off in this case -
Not good to post your e-mail in a forum like that.
At least put like dave@nospamyahoo.com or something. Most people know to remove the nospam part and it keeps the spam robots a little confused
Post your e-mail like that often and you won't be able to find your real mail soon for all the spam!
As for your cables, I don't have what you have so I can't give details.
But if your card has 2 S/video plugs I would guess one is for in and one is for out. You should be able to figure which way you want to go
To put VHS onto the computer you need to connect to the input.
As for composite, yellow is for video and the other two are sound. If your capture device only has 2 rca jacks, maybe one is in and one is out?
Is that device supposed to do output? S-video cables are video only, so if it has 2 connections sounds like one is for output, so I would think it has composite out also? Don't you have a manual to tell you what the connecters are? Have you gone to the manufactorers website and looked?
If you don't have a manual, often there will be one on the website you can download.
If you do have output, and only 2 rca jacks, then you might need to connect the audio directly to your sound cards line in. For that You can get a Y cable that has the little mini din plug for the sound card on one end and two rca plugs on the other end.
Also, are you sure those plugs are S-video? Some cards use a cable that sort of looks like an S-video plug but is not. Like my Card, it has a cable that plugs into the card on one end, but on the other end it has 4 connections. 1 S-video, 1 composite video, 2 audio.
connect pc to tv
By xbill in forum Newbie / General discussionsReplies: 3Last Post: 15th Feb 2012, 14:07 -
Avidemux edit leads to out of sync audio..
By Jmart285 in forum Newbie / General discussionsReplies: 18Last Post: 18th May 2011, 15:35 -
can receive feedfrom rca leads but not via scart to rca lead
By deanno in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2009, 11:39 -
dvd editing leads to unacceptable results
By jamesgig in forum DVD RippingReplies: 7Last Post: 18th Sep 2008, 21:42 -
By jamesgig in forum DVD RippingReplies: 2Last Post: 7th Sep 2008, 01:49
