WUT PROGRAM need to join 2 iso/cue and convert to DVD movie.?
thank a lot
It depends what's in your iso file. You can use several programs to get the mpeg file out, I like Isobuster. Once you have an mpeg you need to see if it's DVD compliant. If it is then you can author and burn to disk, if it's not then you need to convert it to dvd compliant then author then burn.
BTW, you don't need to join the mpegs just author them together and burn away."Art is making something out of nothing and selling it." - Frank Zappa
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 21:33 -
.iso, .img, .cue, etc. to DVD
By Xandal in forum ComputerReplies: 5Last Post: 26th Aug 2008, 12:52 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01 -
cue sheet problem
By Snowcrystal in forum AudioReplies: 2Last Post: 2nd Sep 2007, 13:29
