I've read different posts about burning programs but CloneDVD doesn't seem to work for me and I haven't tried the others.. Currently I'm using DVDShrink to shrink and Nero to burn but it doesn't play on one of my players and the first time I played LOTR2 it froze towards the end. What burning programs do you recommend?
Sorry.. newbie post
Lots of people seem to like RecordNow.
I have Prassi (old version of RN ) and it has never screwed up) -
A couple of the problems theoretically could have something to do with your burning prog, but LOTR stuttering at the end is definately not a burning software problem. You may want to consider your media, and your transcoding/authoring progs as well.
Before I used dvdxcopy, but I hate the warning that they put at the beginning(and the gold version did not record DVD tv episodes). Now I use DVD Decrypter, DVD2One and Nero to burn(DVD9 to DVD5). That seems to work really good for me right now. I like DVD2One better then DVD Shink because D2O figures out the compression rate for you, where as, DS, you have to scroll and figure out the compression for yourself. D2O also uses every bit of space availible on the disc, for best possible quality, where as DS usually has a couple hundred megs of space left. ALSO, D2O has the option to copy the entire disc(menus and all), or main movie. Only plus(and it's a big plus) about DS is that it's free....and free goes a long way! I can definately recommend D2O if you can get it!
false... dvdshrink 3.0 beta 5 has automatic calculations.Originally Posted by derrick972
try deep analysis in dvdshrink it's pretty much dead on.D2O also uses every bit of space availible on the disc, for best possible quality, where as DS usually has a couple hundred megs of space left.
same with dvdshrinkALSO, D2O has the option to copy the entire disc(menus and all), or main movie.
Of course you can get it for $40.Only plus(and it's a big plus) about DS is that it's free....and free goes a long way! I can definately recommend D2O if you can get it! -
im a n00b at this too but i use DVD Shrink and CopyToDVD and its been workin fine for me.
@mrbass
check out a couple of post in the forum, D2O is also known to have a little better quality....also, I am using the old verion of D2O(1.1.3)...the newest version(1.3) is much better then the previous. They added a join feature which comes in handy for me since I have some dvd's that I previuosly had to split in 2.....nice little tool....DVD Shrink needs to catch up!!! :P
Video CD/DVD Authoring Burning program Recommendation
By illyad in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2012, 09:05 -
Free program for Burning extracted DVD files to disc?
By lglrgl in forum Authoring (DVD)Replies: 1Last Post: 25th Dec 2007, 11:21 -
Best program for burning .avi to DVD for DVD Player, retaining quality?
By Calcyon in forum Authoring (DVD)Replies: 1Last Post: 11th Dec 2007, 00:53 -
Best video file to DVD burning program? Any help greatly appreciated!
By Bathouse in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2007, 13:57 -
Whats the best DVD burning program out there?
By Tielurr in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 18:21
