After ripping DVDs, converting the .vob files to mpeg-2 files, and splitting the files into 800mb chunks, both my DVD machine and my DVD software (WinDVD) believe each chunk is only 39 minutes even when they are actually much longer. This happens even when I uncheck the "create standard compliant CD" box in Nero. And this happens when I split the files using either TMPG(mpeg tools --> merge & cut) or DVtool. Same result. Is this inevitable because standard SVCDs at the standard bitrate can only accomodate 39 minutes per 800mb? Or is there a way to write the header so that machines reading the files know how long the clip really is?
Thanks!
Ethan
I only get that if I use multiple Mpegs on a CD. Since it doesnt harm anything I ignore it.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
sounds like the first mpg on the disc is only 39 mins. svcd @ std bitrate (VBR) can be up to 1.5 hours per 800mb.
The electronic components of the power part adopted a lot of Rubycons.
Error Displayed But Still Encodes
By montgal in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2010, 12:09 -
Video Sharing Site longer than 20 minutes
By xeroid in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:03 -
how to get softsubs displayed??
By aruwin in forum SubtitleReplies: 2Last Post: 7th Oct 2008, 02:45 -
Subtitles That Should Only Be Displayed When Foreign Language Used
By urb1972 in forum SubtitleReplies: 2Last Post: 16th Feb 2008, 10:38 -
subtitle displayed in textbox on DVP3040K
By izzat in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Aug 2007, 10:33
