  1. I bought a NEC ND-1300A burner that now has firmware version 1.07 and have been trying to burn "The Matrix" onto a 4.7GB DVD-R by compressing the files and placing them in a VIDEO_TS folder.
    I haven't been able to burn one DVD-R successfully yet. I first got a LEDA 1x DVD-R, and realized that 1x won't work. I just got the 3'rd generation Matrix 4x DVD-R and was told by the company I bought them from they were compatible with my burner if I had firmware version 1.07.
    I have tried burning with Nero 6.0, but that wouldn't even recognize the burner. I then trialed a Nero 6.x version and it recognized my burner. But it would fail on simulation for DVD-Video, or freeze on UDF/ISO. RecordNow DX would simulate discs until it was on about 97% then fail with the 1x DVD-R's. With the new 4x DVD-R's, RecordNow DX will begin simulating then immediately fails.
    I even tried to use Ulead DVD Movie Factory 2 and ImgTool to create an ISO. But Movie Factory 2 freezes up. And ImgTool states that it can't find a Video_TS or some Video_TS.IFO file for v0.89, or that it can't find a VIDEO_TS directory and it must be in the given directory for v0.90 B7.
    Does anyone know what I have to do to burn a DVD-R?
    If everything is infinite then nothing is definite.
  2. Hi Thommers.
    I'm not sure what the cause of your problem is, but you might want to check some of the guides here just to double check you did everything correctly.
    ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
