is ther a program just like this for pc ?
http://www.apple.com/dvdstudiopro/
Adobe Encore might be the best choice.
Scenarist and DVD Maestro can do pretty much anything you can image but both cost a bit more than you're willing to spend and Maestro is no longer produced
THANKS FOR THE REPLY
but with the dvd studio pro the made the x men menu
so i dont think dvd meastro is any good
till now dvd lab is the best out there.. -
ReelDVD 3.0 is the PC equivalent.
I've used DVDSP and Reel a few times.Want my help? Ask here! (not via PM!)
DVDSP 2.0 is built from Maestro technology they got since acquiring the Spruce products. So, for equivalents, I'd say Maestro is the closest in feature sets. And, NO, I don't think they'll ever port it back to PC.
Scott -
DVD Studio Pro "2" is DVD Maestro's code ported over to the Mac - but
what is this "the X-Men menu was produced in DVD Studio Pro" business?
So you're telling me that the menu was made from a template and that X-Men was authored on DVD Studio Pro? I find that very hard to believe.
If you're looking to make "fancy" menus, you should be taking a look at Adobe After Effects.
Don't knock Maestro unless you're familiar with its capabilities - DVD Lab and DVD Maestro are in two very different leagues.
