I posted a request for help converting a PAL VHS tape (made during a vacation trip to Spain) to NTSC in the Capturing section and it disapeared. Did I post in the wrong place? I figured I was capturing Video fron a VHS tape to convert to a diferent format.
I tried capturing the PAL VHS with PCTV and them converting it to NTSC but it didn't work.
What can I do short of buying a PAL VCR?
I sent you a PM.
First of all you need a VHS VCR that can play back a PAL format VHS video. Standard USA VHS VCRs are only capable of playing back NTSC. So you need a multisystem VHS VCR which can play both formats.
Now some multisystem VHS VCRs can do conversion but you DON'T want to do that. You will get better quality if you play the PAL VHS tape as PAL and capture it as PAL
You can then convert the PAL capture to NTSC while doing a MPEG2 DVD encode (or SVCD or VCD etc.)
The computer method of conversion is SLOW but it gives MUCH better results then doing the conversion with the VCR or even one of the more expensive stand alone "digital converter boxes"
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
PAL-N VHS to ntsc dvd
By Paul99 in forum Video ConversionReplies: 17Last Post: 4th Apr 2011, 17:32 -
PAL VHS to NTSC DVD
By Kendo66 in forum Capturing and VCRReplies: 41Last Post: 15th Feb 2010, 19:04 -
Pal S-VHS to NTSC PC
By Jerry1964 in forum Capturing and VCRReplies: 14Last Post: 19th Aug 2008, 09:50
