  1. Anyone know of a good tool to work with TMPGEnc to turn video 180 degrees before/during encoding? How about 90 degrees?
    I tried a couple of .avi tools and the quality seems pretty poor.
    I am going from progressive DV to DVD MPEG.
    Apr 2002
    The State of Frustration
    Can you tell us what you have done so far? We wouldn't want to tell you something you already know.
    Hello.
  3. Member SaSi's Avatar
    Jan 2003
    Hellas
    I suggest you use VirtualDUB and the rotate or rotate2 filters. The first does just 90 degree steps of rotation, the second one allows to set a precice angle.
    You could frameserve to Tmpgenc, but the simplest way would be to save to a new AVI (using the same codec settings) and then load that to Tmpgenc for MPEG encoding.
    The more I learn, the more I come to realize how little it is I know.
  4. Thanks all. VirtualDub seems to be the way to go. I had problems before but now it works fine.
