i need help with this
Results 1 to 18 of 18
i have a mpg1's and i wanna convert them to mpg2's how do i open the mpeg-2 template and where is it located im so new at this!!!!!!!!!!!
Why? MPEG1 is a format supported by DVD and no quality gain can be made when the source is lower.
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS -
If he is making a true SVCD, he must use MPEG-2, right?
Hello. -
that is the problem i don't have any mpg2 files i wana meke my current mpg1 into mpg2 files
Again, why? Convert VCD to SVCD for what purpose?Originally Posted by TommyknockerWant my help? Ask here! (not via PM!)
Converting an mpeg1 into mpeg2 will only result in a loss in quality and lordsmurf and I fail to see any benefit to performing the conversion. Unless we're missing something?!?"Art is making something out of nothing and selling it." - Frank Zappa -
jemel46
Does your dvd player not support the vcd format? Are you trying to make
a dvd compliant video? -
yes it supports vcd but i wanna make svcd because the quality is much better but my dvd doesn'tm support svcd's so im gonna do the header trick but i need to know how to change my mpeg-1 into a mpeg-2
You'd pretty much need to use the templates in TMPGEnc but I'd have to agree with Lordsmurf and Zippy..........you're not going to gain any quality by converting to SVCD. Remember - Garbage In, Garbage Out.
"Hello. My name is Inigo Montoya. You killed my father. Prepare to die." -
Imagine a small framed picture hanging on a small nail. Does moving the picture to a bigger nail make the framed picture bigger? No, even though it's true that the bigger nail can support a bigger picture.
You want to take an mpeg1, convert it to mpeg2 and then do the header trick in order to play it on your dvd player!?!
Don't bother, it will only get worse. Yes, an SVCD is better than a VCD but you need the original source file in order to create a better quality file. Your VCD will look like crap converted to a higher resolution."Art is making something out of nothing and selling it." - Frank Zappa -
Not the VCD but the original? Then just use that to create your SVCD.Originally Posted by jemel46"Art is making something out of nothing and selling it." - Frank Zappa
If you are talking about the source VCD file, that is not going to help any. If you are talking about a higher quality mpeg that was "downgraded" to a VCD compliant version, then you could increase quality.Originally Posted by jemel46"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
How to convert MPEG-4 into MPEG-2 with a Mac
By VidHunter in forum MacReplies: 12Last Post: 29th Oct 2007, 01:23 -
Convert mpeg-4 to mpeg-1 with ffmpegx?
By CollinH in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 23:36
