My Samsung SV-DVD1E does not play SVCDs burnt on a 100 min. CD-R, (870 Mbyte) while the other player I have, the Samsung DVD E235 can play them.
I used a Vivanco 100min. CD-R.
Both players can play almost perfectly SVCDs burnt on 90 min. CD-R (800 Mbyte).
Does anybody have any tip or suggestion to make the Samsung SV-DVD1E to play the 100min. CD-R ?
try different media. I have v good results using infiniti brand. Mostly tho if it dont work, it dont work. Try only recording up to 95% of disc capacity (so your still getting more than 90min cdr) I have checked my 99min discs with nero info tool and they have reported them as being 96/97 mins. Not sure if this true tho. Try vcdeasy to burn.
what did sam sing? :PCorned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
By raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 11:45 -
Samsung VR350. Can't play DVD anywhereelse but in Samsung VR350
By gux70 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Aug 2010, 10:34 -
Samsung BD-P1590 VS Samsung BD-P1500?
By Darkerknight123 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 3rd Jan 2010, 17:51 -
Samsung HT-Z210, Samsung HT-X250
By emmy207 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Mar 2009, 23:06 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 02:42
