I have the lastest Demo version of DVDLab and I really like the app; however I am having the hardest time making it work with AC3 audio. I happen to have DVD Architect and it works pretty well with the same project and making the audio work.
However, I feel more comfortable with DVDLab but can't get the AC3 audio to work,,, I have used Besweet to convert the .mpa to .ac3 and still NO AUDIO......
If someone has successfully used DVDLab and made it work correctly with AC3,,,please help!!!!!!
Results 1 to 10 of 10
If you don't mind, can you list out how "you" do it,,,, somewhere along the line I am doing something wrong and for the life of me I can not figure out where!!!Originally Posted by Michelle
I suspect the problem lies in the creation of your AC3 file. I use Vegas Video for converting to AC3. Unless you have Vegas then unfortunately my method won't be of help to you.
The AC3 files you are creating from the .mpa files must be 48khz. 44 will not work.
Actually I do use VEGAS..... I just got it..... I was using Sonic Movie Factory and upgraded to Vegas..... So how do you make your AC3 audio?Originally Posted by Michelle
I use ac3 with dvdlab and besweet.
in "tools", "transcode audio" set up use of an external transcoder as follows;
select External
Preset = blank
External EXE = select the folder that contains besweet.exe and select besweet.exe
Command line = "-core( -input $INPUT -output $OUTPUT ) -ssrc( --rate 48000 ) -ac3enc( -b 224 )"
(remove the "s) you may want to cut and paste this. This will produce a 224bps 48K ac3 file. (I use 224 as there were problems with some other rates in the pre-release version of dvdlab)
Then you can open your mpa file under input and it will be saved as a ac3. Just hit Transcode.
You can also select a mpa (or wav) file in the assets bin and just hit the audio transcode on the assets bin tool bar.
Hope this works for you.AKA Zaphod -
I have Vegas+DVD. I'm not sure if regular Vegas includes AC3.Originally Posted by mtrichardson
Here's what I do: File - Render As.
Save As type: Dolby Digital AC-3.
Template: Stereo DVD.
If the audio source includes surround encoding (ie from a tv capture) then I also do Custom - Bitstream - Dolby Surround Mode: Dolby Surround Encoded.
HD .m2v and .AC3 Help Needed Please
By lovelylisa in forum Video ConversionReplies: 40Last Post: 29th Jun 2011, 09:20 -
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 21:58 -
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 01:05 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
please help!!!!!!
