just installed pioneer dvr-106d and roxio easy dvd 6 , do I need any more software to take AVI files and put them onto DVD to view on stand alone player ? , these may sound like stupid questions but having read through the forums I am getting more and more confused , somebody please HELP !! .
thankyou
Results 1 to 15 of 15
Best bet is to not start in forums, start with the guides and tools. After you've read up on stuff, it'll be easier to get an idea of exact questions to ask. :c)
Forums will make your head spin if you start there. :cDThere's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Look at the guides on the left unde convert. After your video is converted to the proper format check out the guides under author.
It takes a while. Don't let it get to you. I always suggest a cosy chair and a drink of your choice. :c)
I wish I had that advice when I got into this....
First of all, ask yourself, what do I want?? Then find out from the guides on the left hand side, what you need...
There seems to be a few major realms here. They all blend into each other somehow, but for the most part, are concentrated specifically for
1) DVD's (which falls into the realm of ripping, backing up, authouring)
2)Video Applications (tends to fall in the categories of editing, encoding, frameserving, capturing, and authouring)..
This is a generality, but if you can split the two realms, learn the phrases, and understand the basics, then it'll come to you pretty fast...
Good luck!!!!!! -
ok , back to the beginning .
File from e-mule says AVI
In properties it says MPEG layer 3 ( fantastic quality )
In TMPGenc it will take 3 hours aprox ( is this normal ) to convert AVI -MPEG
If as properties states it is an MPEG can I then put it onto DVD via Easy DVD 6 ( Roxio ) ?
or is there something to do in between HELP........................................ -
Oh, excellent point.learn the phrases
There's a good glossary here as well: https://www.videohelp.com/glossary
Helped me a lot in the early stages.There's no place like 127.0.0.1
Can't say if that's normal since you did not say how long the video is.Originally Posted by lord-lucan
Avi is avi. That mpeg3 is the audio. It must be converted. Yes, more steps to do. Back to your required reading.
:c)There's no place like 127.0.0.1
You probably have either an MPEG-4 file, or a file with MPEG Layer-3 Audio. It's probably not DVD compatible unless its about 4 GB in total. You will have to convert in to MPEG-2 in TMPGEnc, which, as you say, will take about 3 hours.
That's the only way, I'm afraid.
:P -
many thanks ta2 and gees , yes it is Mpeg layer 3 , will now go and convert to Mpeg 2 in TMPGEnc . A few words from you guys gives me the confidence to get on with it , no doubt I will be back at a later stage of this AVI - MPEG - DVD saga , I just thought you could press a button and hey presto a DVD , how wrong I was , still not sure where the Easy DVD creator part comes in though ??.
I don't use Easy DVD Creator, but yes, I disagree with all the packages that say "Make your own DVDs at Home!"
They do not tell you that it takes ages to learn, you need extra stuff to do it, etc. etc.
Just stick with it. Everyone here started off same as you.
And, yes, pop back when you run into trouble, but best way is try each step on your own first, as you're doing. :c)
Good luck and remember to have fun. :c)
Oh, and -- you're welcome.There's no place like 127.0.0.1
Simply put,
Avi to DVD:
1. encode to mpeg-2
2. author with DVD authoring program
3. burn with program of your choice
I know it is a lot harder than that but I have sucessfully done it many times so if you have any questions, Ask, I will gladly answer.
SLICK RICK
Originally Posted by lordsmurf -
many thanks SLICK RICK your statement does clarify things alot.
Keep up your good work helping out us newbies..............
One day hopefully will be able to contribute help to some newbies but I never run before I can walk lol....... -
We were all newbies once, so I know the feeling. When I first joined this site, I did not know anything about video or even computers. But learning from my friends here I can do alot and I am still learning to this day. So visit often, many of us are here pretty much every day, its a second home to us.Originally Posted by lord-lucan
SLICK RICK
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
