    Sep 2003
    Switzerland
    Hi,
    does anybody know how to make the S 500 codefree. At the moment it's on code 2 for Europe.
    Thanks for your help.
    lucas
    May 2003
    Pal Realm
    Have you done a search engine search yet? I know there's a few websites dedicated to listing that info.
    Search first here on the form, but I know I've provided a link to a site I used once. If I re-find it before you, I'll pop back with it.
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
  3. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    last time I looked there was no free remote hack for my DAVS400 as most of the Sony's require a chip mod or a special remote to change the region code. You can buy remotes that make it region free and normally you have to return them
    this is an example of a remote which is from the www.DVDChips.co.uk HERE but it's no good for you as you are in Switzerland
  4. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    Not sure if this works with the DAVS500 but I think it worked on my DAVS400. all it does is display the region though as I don't think you cannot edit it (be careful, try it if you want)
    1 - Turn it on with no disc inside.
    2 - (ON THE EQUIPMENT NOT ON REMOTE) Press and hold both the Display and Stop keys while turning the volume control to the right. When your TV screen fickle, release the buttons. You should be seeing the Service Menu now.
    3 - (Informational Only) Pressing 0, 2, 5 on the remote will show you the region your eq. is set to
    that's another reason why I got rid of it, no free region hack , only option was to buy the temp remote or open the case and put a chip mod inside and void the warranty
    May 2003
    Pal Realm
    Just did a search and found this post on another forum:
    There is no Sony handset hack , it needs to be done by remote (FULL STOP) !!
    I have a Sony DVP-NS305 and the Sony Centre where I bought it said they'd do it for me...for £49
    from http://www.dvd-swaps.co.uk/dvd2001/dvdforums/showthread.php?threadid=3060
