Hello...I've got a Centrum C-100 Dvd Player.
I wonder if there's anyway to update it ,so it would be possible to play raw
mpeg,avi,etc..Files. Instead of having to make a vcd cd, it would be possible to play a ordinary Data cd with videos on...Is that possible to do?
Please tell me!.
Peter
Well, you could of course write your own firmware to make it play mpeg data files, but that seems like a long shot...
/Mats -
And divx/xvidOriginally Posted by mats.hogberg
Hi.
I have an Afreey LD2060 (its a sampo clone), you can update the firmware via a CD-R. If you go to www.area450.com and look at the firmware section, there r lots of firmwares for various models and you can even change them to play raw files, i recently changed mine so it would play .VRO DVD-RAM files.
They are mainly for Sampo players and various clones but i believe its possible to re-program your eprom inside your player, I dont know much about it, but its worth going to have a look. -
Ok, thanks a lot for telling me.....
Seems like it's only to keep doing vcd's then. -
One advantage is that you get 100 MB extra if you author an mpg as (S)VCD compared to if you just wrote it as a data file.
As the authoring stage isn't that time consuming, I think I'd go this route even if my Centrum played raw mpeg...
But I'd really like a player with reliable DivX/XviD playback (but on the other hand - I already have! My computer...)
/Mats
How to play raw DV files?
By Bonie81 in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2011, 08:00 -
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 12:25 -
How Do I Play Raw DV Stream Files on a TV?
By NY2LA in forum Software PlayingReplies: 97Last Post: 30th Jul 2011, 00:21 -
Do Any Blue Ray Players Play raw m2ts files?
By wulf109 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Nov 2010, 22:41 -
How to strip ip header from raw mpeg
By aj99v in forum Capturing and VCRReplies: 0Last Post: 11th Mar 2010, 14:54
