Does it have any sense to save captured AVIs as ZIP files on a CD or DVD for encoding with, on this moment, non existing encoders in the future?
Zipping video files does not work well (will not reduce filesize), think about it, you have already compressed the file using a video codec, divx xvid etc. So if you want to archive just save the avi file to disc there is no point in zipping it.
Craig,
Thanks for your reply.
I meant not compressed AVIs, these are capture files captured with DVIO (13GB/hour) from VHS via Canopus ADVC.
I also made DVDs (mpeg2) from these files.
But I thought: there will be development in encoders in the future.
So when I save the uncompressed AVIs compressed to ZIP, I can secure the source for future encoding. -
Oh right, I still don't think you will get much compression by zipping it (DV is still compressed video), but you could always try and see. I find the best method of archiving is to keep the DV tape.
Windows 7 does not see my Zip Drive
By kimco52 in forum ComputerReplies: 16Last Post: 22nd May 2010, 20:16 -
.ISO zip file
By nodollas in forum DVD RippingReplies: 5Last Post: 10th Feb 2010, 17:07 -
What is your most used zip compression utility?
By yoda313 in forum PollsReplies: 39Last Post: 30th Jun 2009, 16:00 -
AviDemux .Zip vs .Exe
By gonwk in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 18:53 -
Can't unzip ffmpegXbinaries20060307.zip
By cerebusthe2nd in forum ffmpegX general discussionReplies: 4Last Post: 9th Dec 2007, 08:39
