I've been making VCDs but they only play in computers. They never play in VCD players.
Methods used:
I export from Avid Xpress as a quicktime, compress to MPEG-1 in Media Cleaner (using the PAL VCD setting obviously), then burn to a CD (have tried both VCDeasy and Nero).
Questions:
1) Why do these VCDs play only in computers? I have tried different types of blank CD-Rs and CD-RW. These VCDs are intended to be used in Pakistani VCD players.
2) Should I try a different program to burn or compress? Media Cleaner seems like the best program for compressing and it plays fine on the computer so I assume it is either the burning or the type of CD used.
3) Are there certain types of CDs that are better to use for VCDs?
4) Can this be caused by the CD burner? I'm using a Dell system so I assume it would be good. I've also tried burning at 1x. No luck.
My problem is that I want to give out VCDs that will play everywhere and obviously these only play on laptops. Thanks for your help.
Also, if I can't get these to work it might be better to just make multimedia CD-ROMs with the mpeg-1 files. Can anyone recommend a good, simple program that will autoplay MPEG-1 files? It would be better to have them as VCDs but my worry is that I'll be giving out VCDs that people will try on VCD players and they won't work.
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
DVD plays on Computer but not built in TV DVD player
By crawlfish in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2008, 07:35 -
dvd plays on stand-aone player & TV, but not on computer
By ibzomie in forum Newbie / General discussionsReplies: 1Last Post: 19th Jan 2008, 15:18 -
Foreign DVD plays on computer but not on DVD player
By johnharlin in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2007, 22:28 -
DVD plays on Sony DVD Player but cannot be read by Computer
By jeneralzod in forum DVD & Blu-ray WritersReplies: 3Last Post: 28th Jun 2007, 21:35
