When I burn a DVD with DVDXCOPY Express using a DVD+RW, it works fine. If I use a DVD+R, it burns coasters even though DVDXCOPY says it finished successfully. I am using Maxell RW's and Memorex R's. Please help!![]()
Why not contact 321 Studios for help, after all they made the software and they do have tech support. Or you could go an easier route and use DVD Shrink and your favorite burning program to get the job done. I would also make sure you have got the latest update for DVDXCopy as well as the latest firmware update for your DVD writer.
Black Magic Media Express Problems
By Decerto_LethaL in forum Capturing and VCRReplies: 0Last Post: 13th Dec 2011, 09:39 -
Problems writing with nero vision express 3
By tatester in forum Authoring (DVD)Replies: 3Last Post: 11th Feb 2009, 16:38 -
Express
By webmaster P in forum DVD RippingReplies: 0Last Post: 20th Jan 2009, 21:27 -
Outlook Express problems
By rhegedus in forum ComputerReplies: 6Last Post: 16th Apr 2008, 17:07 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 16:49
