hi.. I'm trying load transferred video from dv tape(avi type 2) captured via dvio tool into tmpgenc to convert them into dvd format for but\rning but I keep getting error message that file can not open or unsupported
Hoe can I load this dv file to tmpgenc. I checked environmental settings in vfapi and changed the priority or directshoe and also avi vfw reader to 1 and but still no success..help please
Try installing the mainconcept dv codec
hi.. are there any other options.. I can not seems to install the mainconcept dv codec gives me initialization error when installing.. besides its not free. ..
The canopus codec didn't work for me. I can't remember why. I did a little diggin with google and found a codec from Sony. It works fine and it's free. The only drawback is that you'll need to invest about a half hour of googling time. I would post a link, but I don't remember where I downloaded the file.
If you want, I can e-mail it to you.
HDTV2DVD does not load up TS-file
By feilofix in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2008, 14:25 -
avisub blocks when I load .avi file
By ebergi in forum SubtitleReplies: 2Last Post: 23rd Jun 2008, 17:50 -
How to load .ts file into HDTV2DVD?
By JR.S in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2007, 02:59 -
Trying to load .ts file to DVCD2DVD
By movieman123 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 18th Sep 2007, 21:37 -
TMPGenc Xpress 4/VobSub cannot load .avi with subs
By varu in forum SubtitleReplies: 3Last Post: 14th May 2007, 19:26
