    Apr 2003
    brisbane, australia
    Have converted video file to mpeg with Tmpg. Viewed converted file with Windows media player, video was in sync and played perfectly. Went to burn with vcdEasy message came up that file needed autopadding, did so with simple multiplex using Tmpg. Burnt file then founf audio was out of sync by half a second(audio before video).
    Why would audio be out of sync should I have NOT auto padded? Have had this problem a couple of times.
  2. I had problems with this myself. I couldn't find a reason for it or a way around it. I changed my burning program to Ulead Dvd Moviefactory and have never looked back. Far superior program that allows scene selection, background music upon starting the dvd/svcd/vcd as well as in the scene selection. Never had a problem with it and i recommend it highly. I hope that i have been some help to you!!!
  3. Originally Posted by sir_hsv
    Probably a much better solution to my one...
    Nero works fine in my experience, but from what sir_hsv just said, is sounds like Ulead DVD Moviefactory is much better.
