  1. For eample I really like this stick figure fighting movie. Is there a way to save it on my computer?
    http://www.hackernetwork.com/flash/stickdeathx.shtml
  2. Falsh videos are saved to your Internet cache. Just copy it out of the folder conatining the cache. You may have to look at the source code of the webpage to figure out the file name.
    In this case its hnad.swf
    However, the file in your cache may have a number inserted into the file name like hnad[1].swf
    Also, you will need to copy the file out of the cache folder before it will become playable (I don't know why that is).
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  3. Theres also some Freeware that will make it alittle easier to do. I think one is called FlashHunter.
    Check www.download.com
    I remember the day I spent collecting all of the Strongbad emails, man that took a long time.
    "Sleep-
    Those little slices of Death;
    How I loath them."
  4. Roboflash Extractor does it too, its a complete toolkit for taking apart Flash files and viewing actionscript code.
  5. you can also use the very good program webzip, which allows you to make a ghost copy of virtually any website. Even if you just wanted that link with the film have it go there and then have it dl that page only. Works really well
    "in the words of Strong Bad: IT'S OVER"
