I convert with TMPEnc with tooLame as the audio converter. Normally, this works fine, but lately, for some reason, the audio is very screwy. It comes out low quality with high bass and weird treble and very high pitched. I tried using TMPEnc's regular sound converter, same thing happened. Same with using either converter after using VirtualDub to make a .wav file. It seems that anything that goes through TMPEnc gets screwed up sound. How do I fix this?
Hey cool, shadow puppets.....
What are you trying to burn? A DVD, VCD, SVCD, etc?
What you are probably seeing is an audio sampling incompatibility.
If you are capturing from DV, the sound will be sampled at 48kHz, VCD and SVCD require 44.1kHz sampling and TMPGEnc does a very bad job of conversion.
If you are capturing audio with a sound card, make sure you are sampling at 44.1kHz.
TMPEnc Authoring Works 4 Problem with input AC3 Audio (5.1 channels)!!!
By JackyWang in forum Authoring (DVD)Replies: 10Last Post: 22nd Jun 2011, 11:46 -
Problem with TMPEnc DVD Author 3
By ebadillab in forum Authoring (DVD)Replies: 11Last Post: 28th Jul 2009, 07:23 -
Progressive AVI encoding to DVD in TMPEnc - interlaced?
By Xoanon in forum Authoring (DVD)Replies: 16Last Post: 9th Jan 2009, 12:01 -
error in tmpenc
By php111 in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2007, 08:56 -
Problem with TMPEnc
By Technophobe in forum Video ConversionReplies: 3Last Post: 28th Jul 2007, 17:44
