Ok I have been trying to figure out this problem for months. I am beginning to beleave that it is the capture card at fault.
I have been trying to author 5+hr on one dvd. I have tried to lower the bitrate to 1500/1800max, i have tried captured vcd with audio at 48k, and the same thing a svcd. The results with dvd-lab and most author programs is the audio is out of synch on the dvd but the origional mpeg file is fine. With moviefactory2, the audio is in synch but the chapers point to the wrong location.
I would like to know if anyone has had any luck recording 5+hr on one dvd. If so, what capture card are you using?
Results 1 to 1 of 1
PVR-250 and Capture Software
By statman24 in forum Capturing and VCRReplies: 5Last Post: 27th Nov 2008, 14:38 -
Problem installing pvr 250 on Windows vista 32 mce
By heman28 in forum Capturing and VCRReplies: 2Last Post: 10th Mar 2008, 22:18 -
new pc and my hauppauge pvr 250
By heman28 in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Jan 2008, 08:33 -
Want to replace Hauppauge pvr 250, what should I get?
By heman28 in forum Capturing and VCRReplies: 9Last Post: 25th Jan 2008, 09:25 -
Hauppuage PVR 250 problem
By jwfc in forum Newbie / General discussionsReplies: 4Last Post: 26th Sep 2007, 15:40
