how can I get rid of the "not enough memory" when using nero to burn vcds??
You can start by NOT making double posts on here about the same topic...either get a RAM defrag app, shut down all other apps besides Nero, or by more RAM
thank you.
I have enough memory I think...384megs.
what does the ram defrag app do and how do I use it please? -
What version of Nero, Nero has recently posted a link on their website (on the download page) in case you are having problems creating VCD's or SVCD's. i don't know exactly what it does, but it might be your answer.
Another idea is to check your swap file (Virtual Memory) if you turn this off this is where your problem is.
Alfonso
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 02:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 02:52 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 10:38 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 11:46 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 10:38
