Hi all,
First I got a Panasonic DVD recorder that broke down and I did not like the DVD-RAM discs(this format will probably be gone in a couple of years, my opinion). I then decided to switch to Philips DVDR75.
It worked fine in the beginning, I recorded movies on DVD+R and DVD+RW without problem.
Suddenly after one recording on DVD+R media the DVD-recorder will not accept DVD+R discs. When I close the tray the recorder just spit it out again - no error messages or anything.
I did unplug the power and did reset the machine, but still the same problem.
Anyone else with this problem or anyone with a solution?
(I will carry the machine back to the store on friday to see what they are saying!)
Bye
Patrik
Results 1 to 1 of 1
Philips DVDR3576H/37 - Burned Discs Won't Play in Xbox, PC DVD Drive
By jbd5010 in forum Capturing and VCRReplies: 18Last Post: 20th Mar 2011, 03:11 -
Problems with Philips +R DL discs
By carlmart in forum MediaReplies: 17Last Post: 29th Sep 2010, 07:24 -
Philips DVDR75 overwriting existing titles
By Rletson in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Dec 2007, 17:38 -
Philips 20X SPD2413BD won't read 8cm DVD-R discs
By nlec in forum DVD & Blu-ray WritersReplies: 1Last Post: 5th Jun 2007, 11:03 -
Philips DVDR75 worth?
By stantheman1976 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd Jun 2007, 11:48
