I have an ATI 7500 AIW card and I am wondering, is it possible to 'dump' a VCD to a VHS tape ? I can't connect my DVD player to my VCR and the TV out on my card shows the computer output. So, is there a way to send the signal just from my VCD out from my computer so that I could record it to a VHS tape ?
Any insights would be most appreciated !!
Thanks to all !!!
All DVD players should be able to connect to all VCRs. All of them in the past 10 years have RCA/composite connections.
Play the ATI output fullscreen and use a DVD player software.Want my help? Ask here! (not via PM!)
Alternative: play the VCD on your PC, with the TV-Out active. (Turn off your screen saver and power saving settings.) Then you can record onto VHS what displays on your PC monitor (which should be the VCD).
VCR buying guide (S-VHS / D-VHS / Professional)
By lordsmurf in forum RestorationReplies: 326Last Post: 2nd Sep 2025, 05:10 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19
