I have two DVD's that I'm authoring for friends (their home movies). I am capturing their old VHS tapes with my Dazzle DVCII into MPEG2 DVD.
One of them had several bad spots on the VHS tape, so I went into TMPGEnc DVD Author and edited out some of the bad frames, and removed some other unwanted chunks.
I then authored the DVD and burned it. When I play the DVD on the PC, it seems to work fine all the way through. When I play it on my standalone DVD, there are certain areas that it will get to and just stop and I can hear the player sort of "stuttering" on the DVD. It stops at the same areas each time.
I then burned the DVD onto a completely new DVD (thinking the other one might have a defect). It too played fine in the PC, but on the standalone, it started stuttering again, but in new places.
Is it possible that TMPGenc DVD Author might have botched something in the areas that I edited out? Could that cause this?
The 2nd DVD that I was authoring didn't have as many bad spots, so I didn't really edit much out of it and it seems to work fine all the way through, so I'm just guessing this is the problem, but wanted to see if anyone else was having this problem.
If this is a problem, would the solution be to use another editing tool to remove the offending frames from the original MPEG and then use TMPGEnc DVD Author?
If it stuttering in different places on two dvd's with same files on it I'd say it was media.
How did u burn it ?
If I burn with TDA - wont play on my standalones, I have to use nero. -
I don't see how cutting out a bad spot would be any different than normal cutting. So far I never had a problem myself.
Only thing my disks are regularly played on is a norcent dp300, but they work good when they have been takin other places and used on other players, but that's not alot.
Backups I burn with Nero, Self authored I use Tmpgenc DVD Author for both authoring and burning.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 11:00 -
How to Make Authored DVD INTO .ISO WITH TMPGENC DVD AUTHOR
By Chupes in forum User guidesReplies: 4Last Post: 19th Aug 2007, 18:38
