dose any1 no what this means "not enough memory!adjust memory buffer size 8MB"im have problems with burning
this is what the log file said
###################### Source Disc/Image Information ######################
Type: CDRWIN Image file
Path: C:\WINDOWS\Desktop\BRIANS FILES\ps2-psx-roms\ps2\maximo vs army of zin\
kal-max2.bin
Session: 1
Track: 1
Session 01:
Track 01: Mode 2 Form 1, Length: 341082(666.2 MB), Address: 000000
####################### Dumping/Recording Progress Log #######################
AM 10:25:30 Processor info: Intel(R) Pentium(R) 4 CPU 1.80GHz (1793MHz)
AM 10:25:30 Memory Available to Windows: 130,024 KB
AM 10:25:30 Not enough Memory! Adjust memory buffer size to 8 MB.
AM 10:25:30 Image file loading: C:\WINDOWS\Desktop\BRIANS FILES\ps2-psx-roms\ps2\maximo vs army of zin\KAL-MAX2.CUE
AM 10:25:30 Source Info: Session: 1, Track: 1, Length: 666.2 MB / 075:47:57
AM 10:25:32 (E
LG CD-RW CED-8080B (1:1): Recording Method/Speed
AM 10:25:32 Recording - DAO / SAO - 8X (1200 KB/Sec)
AM 10:26:13 (E
LG CD-RW CED-8080B (1:1) - [Write PREGAP area ERROR]: -0000150 - 00000000
S:KEY - 04/09/00 - "Track Following Error"
AM 10:26:13 (E
LG CD-RW CED-8080B (1:1): Recording failed!
AM 10:26:13 Error message: [04/09/00] - Track Following Error
AM 10:26:13 (E
AM 10:26:13 Image file loading aborted!
dose any1 no what this means -
This isnt the right place to post this type of message...but anyway, what program are you using?
Devanshu- doesn;t the title name give a hint my friend?! lol
it seems to be talking about the Buffer size of the CDRW- although a CDRW with an 8meg buffer size seems very small. go into the burn options and make sure it is using the max buffer size avaliable, and also ensure buffer underrun protection is enabled.
also, try changing the media because it seems you are getting buffer underruns1)Why Not Overclock a little?! speed 4 free!!!!
2) If your question has anything to do with copying PS2/PC/XBox games, find a more appropriate website -
Lol...whoops. I tend to ignore the obvious.
what alcohol is saying is adjust the memory buffer in its program settings to 8 mb cause you are burning with not enough memory,goto file/options/recording and adjust memory buffer size to 8 mb,your burner doesnt have buffer underrun,its only 8x burning and is fairly old.
my burn will burn at 2x but it will not burn at 8x 4x.y is this.i never have this problem be4.did i f#ck up my setting on my PC.
nero dose not work nether.same problem.nero burns at 2x but not 4x8x.when i burn at 2x it seems to not burn right.the vcd will not play on my dvd player
PS i have burned 100 of vcds/svcd and never had problems
Research finds many women need alcohol to enjoy sex
By zzyzzx in forum Off topicReplies: 0Last Post: 2nd Oct 2009, 15:52 -
Alcohol 120%
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2009, 13:59 -
Alcohol 120% files into a DVD5
By P T Wheatstraw in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2009, 23:16 -
Problem with Alcohol 120 mounting images on system start
By Talayero in forum ComputerReplies: 1Last Post: 29th May 2008, 12:53 -
Newbie Question: Can I use Alcohol default settings to burn DVD-5?
By ShadowRider in forum DVD RippingReplies: 1Last Post: 11th Aug 2007, 15:56
