How would I go about bringing down the levels of my .mpa audio? Some of my video clips(I've got 6 clips) are louder than others. Do I have to go back to my original .AVI and fix it there, or is there a way to fix it after the fact? Thanks![]()
are they louder in the original avi files, or are they only louder after encoding?
be aware also that mpeg audio isn't standard to NTSC video, so some players may play it back louder or distorted - mine does, so I've switched to encoding most audio to AC3.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Hey housepig,
It's not louder than the original avi's. It's not quite to the point of distorting, but it's close. Is there a way to bring down the levels of the .mpa file, or can that only be done with an AC3?
The hoops you have to jump through to get a DVD built is amazing. I can't believe there aren't more standardized procedures and formats for DVD authoring. It seems to be all over the map. Oh well, you do what you gotta do....
Originally Posted by housepig
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 09:53 -
Merging MPA video and MP2 audio files
By makf in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2009, 19:13 -
DVDLab Audio Playback
By alhall in forum Authoring (DVD)Replies: 1Last Post: 26th May 2008, 09:00 -
Good free program to join .mpa audio and .mpg video ?
By geek2330 in forum Newbie / General discussionsReplies: 6Last Post: 5th Nov 2007, 09:34
