Everytime I start TMPGenc up, no matter which version, I get an error - write error occurred at 77f67f26 of module ntdll.dll with 00000000, I have tried a clean installation of Windows XP Pro, I have checked the memory etc, that checks out ok. I can run through a full encode using CCE but since the resolution of the sources that I using are never a DVD standard size I can't put them into an authoring program.
Any-one got any ideas?
Are you authoring downloaded files ?
Read up on Frameserving. You can open your video
in VirtualDub . resize it , and feed that directly to
CCE or TMPGenc without an intermediate file.
Avisynth will also do that but it's a little strange if you aren't
a programmer type. -
Did you do the Frameserving thing ?
or are you just using VirtualDub only ? That means you will
have an intermediate file which is either way too big or compressed
with some loss of quality.
The thing to do is feed the uncompressed output of VirtualDub
directly (without a file) to TMPGenc or CCE. Has lots of advantages like that.
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 12:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 15:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 16:46
