  1. im using nero to burn a mpeg"converted with TMPGEnc and its converted right"and its not burning the buffer will not show up it kicks the cd out.and no other of my burning programs work the same thing happins with nero
    PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
  2. What size is the file and what are you burning it as.
  3. the size is 600 and the format is bin/cue i use Alcohol 120% mpeg i use nero but the same problem the cd just wont burn i have bin burning mpeg and bin/cue 4 a long time i dont no what happin dose any1 have any ideas
    please help any ideas will help
  4. Have you tried extracting the mpeg from the bin and reauthoring it.
  5. no the mpeg is vcd format the bin/cue is a ps2 game and i cant burn anything.when i try 2 burn bin/cue"with Alcohol 120%"it said "image file loading aborted"then it said"something is wrong with the recording procedure please check the log file and report any errors to technical support"do u no what its talk about
    the mpeg bin/cue i no there is nothing wrong with the file this just started
