Can anybody confirm if SP2 will import .dts files?
Haven't had time to upgrade yet, but if it can, that'll clinch it......
Many thanks......
Be part of the process, not just subject to the outcome.......
pants on, pants off, pants the floor.
This cracks me up every time I see it
glad you the quote.
supposedly an ap called tfdvdedit, which should soon be out, see www.tfdvd.com for more info, supposedly in the version coming out or in the next version you'll be able to add dts this way. this is an ap that's to be used in conjunction with dsp2, i think it's similar to ifo edit on the pc, this is a mac only ap too. but you would build the dvd then go in and edit the build files and add your dts track that way. i'm dying to get my hands on this ap to try it out. but still not sure when it comes out or how much it is yet.pants on, pants off, pants the floor.
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 08:40 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 07:06
