I think this subject has been posted before. Sorry I couldn't find it in the forum. My question is regarding WIN 98SE FAT 32 that does not support files bigger than 4 GB. It is my understanding if running XP or WIN2000 PRO the files are able to be more than 4 GB because it is NTFS.
I'm researching info before I purchase a dvd burner. My question is if I continue to use WIN 98 SE will I be able to back up my dvd movies successfully on dvd-r or dvd+? Or is it necessary to upgrade to WIN2000 PRO or XP?
Debating yet whether to purchase the PLEXTOR 708 internal or external dual dvd burner.
Thanks in advance! I appreciate any advice anyone has for me.![]()
You are fine in file mode (usually 1GB each) but can't make or burn image files bigger than 4GB in FAT32Originally Posted by budz
https://www.videohelp.com/forum/viewtopic.php?p=658139#658139
Burning full disk ISO images is very handy but not vitalYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
The limit in FAT32 in 4GB *per individual file*. This does not mean that you cannot have a VIDEO_TS *folder* that is greater than 4GB. As long as none of the individual files (VOB, etc.) are greater than 4GB (highly unlikely), you should be OK.
Amateur Question: My DVD9 doesn't support AC3 Audio
By Keziapurrs in forum AudioReplies: 15Last Post: 10th Jul 2011, 20:03 -
FAT+ troubles with .mkv merged files
By fabpozzi in forum Media Center PC / MediaCentersReplies: 2Last Post: 19th Jan 2011, 11:29 -
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 08:40 -
Firefox3 doesn't support realplayer plugin
By toddfv411 in forum Video Streaming DownloadingReplies: 4Last Post: 9th Jun 2008, 19:27 -
How can I install PPro2 on system that doesn't support SSE2?
By Sean_ve99 in forum EditingReplies: 1Last Post: 26th May 2007, 08:33
