I am sending someone some burnt copies of a TV show but dont' know if it will play in the UK. I'm using DVDdcrypter to rip the file from my set and then using it to copy it. There is no encryption or anything. Will it work in the UK dvd players?
DVD Decrypter makes it region free but they are going to need a
multisystem player that can play NTSC discs on PAL TVs (and vice versa)You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I live in the UK and my DVD player and PS2 and 2 TVs all play NTSC DVDs. Are you able to ask your friends here what player(s)/TV they will use?
If so, you can easily look it up for them and verify whether it plays NTSC.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Just about all UK DVD players will play both PAL and NTSC discs, if you want to know what players will play DVD-R or DVD+R look at the DVD compatability list.
As long as we are on the topic, I'll ask.
I heard that is it a requirement that all new players in the UK handle both NTSC and PAL. Is that true or do they just happen to handle them?"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
Software to play back AVCHD-DVDR
By cheerful in forum Software PlayingReplies: 5Last Post: 18th Nov 2009, 00:14 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
Will 720P and 1080P dvdr discs play on a Non Blu Ray DVD Player?
By donfm in forum Newbie / General discussionsReplies: 21Last Post: 31st Mar 2008, 15:45 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14 -
Can dvdr's recorded in the US play on UK/European players?
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 2Last Post: 26th Sep 2007, 09:58
