Hi Just wondering if I can get some advice : )
Is there a single authoring program that is easy to use ie. that you can take an AVI file which is for example 715mb.....convert it to DVD and burn it to fit onto a DVD-R disk using the one program.......
I have uninstalled Ulead DVD Movie Maker two. I loved the easy to use layout/menus and stuf but it had never ending problems....never even burnt a single DVD with it in the end. I would change all the settings using the Bitrate calculator and would start converting...get up to 60 % and then come up with errors...same thing with every file I tried. I got the same thing with Ulead DVD Workshop. I did manage to burn a couple of small sections of my files but they were so out of synch I gave up.
Please if someone can let me know of an easy to use or popular DVD Authoring Program that would be excellent. Main thing is if it has an option where you can select the disk type and it just makes it fit to it would be great.
