i have just downloaded what lies beneath and am converting it from avi to mpg using TMPGEnc.
The program is i cannot convert the video part of the avi and get a message saying that the file cannot open or is unsupported. However, I can load the audio file ok
Any ideas please
Thanx
You probably not got the codec installed for that type of AVI, click your right mouse on the AVI and find out what it is, then check your control panel > Multimedia > Device's > vidio codecs to see if you have it.
Its probably the Mpeg 4 V1,2,3
thanx, can u tell me where i get mpeg 4. the video format of the file says
720 x 480
233641 Frames
29.970 Frames/Sec
95 KB/Sec
Unknown Format
Problems converting MP4
By Nikar in forum Video ConversionReplies: 4Last Post: 17th Jul 2010, 11:39 -
Problems converting using ConvertXtoDVD
By nadizo in forum Video ConversionReplies: 4Last Post: 10th Jun 2008, 20:29 -
problems converting to flv
By devriesfilms in forum MacReplies: 7Last Post: 2nd Apr 2008, 12:36 -
Different converting problems
By saiden22 in forum Video ConversionReplies: 3Last Post: 2nd Jan 2008, 12:29 -
problems converting to mp4
By jedibri17 in forum Video ConversionReplies: 8Last Post: 28th Dec 2007, 22:20
