I want to convert my xVCD (720x480, 2500bitrate) .DAT files to a DVD-ready mpeg2 file (720x480, 8000bitrate).
I started using SVCD2DVD, but I think it may be the wrong tool. I don't want to trick the DVD to accept the former xVCD mpeg file. Instead, I want to convert it into a proper mpeg2 file as if I was converting from AVI to DVD-quality mpeg2.
Am I mistaken about SVCD2DVD? Is that exactly the tool I should be using? Or is there something else that I should use.
Thanks!
A Mac tool that can author .mpg to DVD folder for buring
By Sam0403 in forum Authoring (DVD)Replies: 5Last Post: 5th Mar 2012, 14:49 -
Want simple tool for chapter links within single mpg file
By salring in forum Authoring (DVD)Replies: 2Last Post: 7th Jan 2011, 22:21 -
Any free tool for batch conversion from VOB/MPG to DV AVI
By arminio in forum DVD RippingReplies: 5Last Post: 15th Oct 2009, 16:14 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47
