  1. ok guys...in my Daewoo DVD-5800 player...it used to be awesome..
    but for some reason now..
    i start to see a little static whenevery i play any dvd with this player..
    i play Original and dvdr's in there and now it's starting to be staticy...
    when it loads..there'll be a lot of static..but when it plays...i see a tad bit of static..
    at first i thoguht it was the movie..but i changed dvds and watched another one..and it was still static..
    is there like..a DVD Cleaner..?
    like how there's CD Cleaners..where you stick a cd in and it'll clean it..
    after noticing this..i changed my player and tested it out in my other dvd player...and it played fine..no static...
    can someone help me out?..i'll have to search in google to see if there's any dvd cleaners out there...
    thanks guys...
  2. if you mean theres static on the screen,then see if all the connections are properly inserted,and theres no loose leads
